c-rad »
https://forums.nicoclub.com/c-rad-u19918.html
Fri Dec 31, 2004 1:21 pm
Ok, after a little more research I guess you CAN'T use the Z32 diff cover? Am I correct? If so, I think this will be my plan...pick up both diffs, swap the output flanges from the J30 onto the Z32. The Z32 won't have the ABS sensor so I won't have the driveshaft issue. Then I will just whore out the J30 LSD assembly minus the output flanges on ebay and try and get money back. And again, for reference, the J30 diff DOES have the 6 bolt flanges.... 3 sets of 2. So does that sound like an okay plan?
