J30 or N/A 300zx VLSD?
WhItES13
First off this is not a question i could find an answer through the search. Here is my situation a junkyard around me has a 90 and 91 300zx differential and 95 J30 for the same price. Should i buy the j30 differential and just bolt it up, or get the 300 differential with the j30 out put shafts(for a little bit more money) so i can retain the same gear ratio?So i guess i am asking how big of a difference is the J30's 3.91666 gear ratio against the stock 4.083636 ratio that the 240 and 300 share? Please dont tell me to search i already have tried no answers.Thanks in Advance!!
TurboKA37
a .4 difference so when ur speedo says ur going 100 ur actually going 104. i have not done this upgrade yet but i would go with the J30 for ease of installation and i plan on putting some power down so the j30 should help a little
240dreamer
Car: 95 240sx SE
how much are the differentials? and with or without output shafts??? i'm looking into doing the same thing, but i own a 95 so the J30 would be easier as TurboKA said...
WhItES13
I do not know how much they r asking for the output shafts. They are asking 250 for the J30 and the 300 pumpkins. Anymore feedback from people who have done it both ways.Thanks!!
240dreamer
Car: 95 240sx SE
what were you going to do about the output shafts???
WhItES13
From what i have read u can use the 95 and newer J30 output shafts suppost to be the same part. Somebody correct me if I am wrong.
240dreamer
Car: 95 240sx SE
ok, cuz i read something about not being able to use the stock 240sx shafts because of one shaft having to be longer on one side than the other... but i could be wrong. i suppose using the J30 shafts makes sense since it's a direct bolt on for my 95 240...hehehe:)
