J30 once and for all
Nissan-S14
Car: 95 Nissan 240SX SE
Can someone please tell me in a straight out answer. i have tried searching for weeks and weeks and im getting tired of different people telling me different things.
WILL A 95 AND UP J30 VLSD FIT A 95 240SX SE WITHOUT ABS.
DO I NEED THE OUTPUT SHAFTS/ AXLES FROM THE J30 ?
Someone please HELP!!!
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
If its a '95 and up j30, yes it will fit with no modification. If its older than '95, you need the input shafts.
Nissan-S14
thank you
clearview
i put a 96j30 vlsd w/abs in my non abs 95se. i replaced the drive shaft because it was too long. the j30 rear w/abs is longer . i have heard of others who have used the longer drive shaft . i felt that the fit was too tight and replaced it with the abs drive shaft which is shorter. other than the drive shaft length it was a direct bolt in.
Nissan-S14
The problem is, I have the Enjuku Racing Aluminum Drive shaft non/abs. So i cant really change the driveshaft!
Structure240sx
hey nissan-s14- i have the enjuku d/s do u notice any vibration with it? in 5th gear at 2k rpm i get alot of vibration but i also have nismo mounts and fidanza flywheel
Nissan-S14
Structure240sx wrote:hey nissan-s14- i have the enjuku d/s do u notice any vibration with it? in 5th gear at 2k rpm i get alot of vibration but i also have nismo mounts and fidanza flywheel
No nothing at all, its perfect.
