Postby
matt169 »
https://forums.nicoclub.com/matt169-u10334.htmlSun Nov 02, 2003 1:33 pm
I have a 95 J30 with 267,000 much enjoyed miles. I have been very lucky with this car to have no major repairs. transmission shifts great and engine runs great. About a month ago I noticed smoke from under the hood and found the oil dip stick pushed up and oil had come out from the dip stick. After getting some help on this forum I changed the PCV valves today. They were completely clogged up. I drove around today some and am still having the same issue. While the car is ideling I can remove the oil dip stick and hear lots of pressure release. It only takes a couple of seconds running to biuld up enough pressure where you can here air rushing out. I have since bought an 01 QX4 so I am not without a ride but really want to get this running again as it is in supprisingly good shape for 267K miles. I don't plan on driving it anymore till it is fixed as I fear the gaskets/seals will get wasted (may already be) with the pressure building up. What else should I go after that could be allowing pressure to build up?
Postby
maxnix »
https://forums.nicoclub.com/maxnix-u127.htmlSun Nov 02, 2003 1:33 pm
PalmerWMD wrote:I hope your not right Dennis...Fred..
I hope it's not Dennis' left, either. I do think Q45tech is correct in diagnosing the rise in pressure in the crankcase while operating as failed rings.
A not unexpected problem with 267K miles on an engine with a clogged pcv valve.
Postby
matt169 »
maxnix wrote:I hope it's not Dennis' left, either. I do think Q45tech is correct in diagnosing the rise in pressure in the crankcase while operating as failed rings.
Postby
elwesso »
https://forums.nicoclub.com/elwesso-u5248.htmlSun Nov 02, 2003 1:33 pm
Well..... id say after 267k it doesnt really owe you anything..... Especailly since you say its been basically trouble free.....
Id keep driving it until it dies for good, and then see about a used engine..... Maybe for extra measure make a hole somewhere so the pressure can escape.... (may or not be a good idea, id like to get some extra input) They are probably gonna be real cheap since they are the same engine as the 300zx..... Keep your eye out on ebay for japanese take out engines......
Postby
maxnix »
matt169 wrote:Is $350 from the local junk yard my best option?
I would think that rebuilding a VG30DE would not be a daunting task for an independent familiar with Z32 overhauls. Thid might be an atractive option if the rest of the car is pristine.
Look for a race engine preparer. Where are you located?__________________Brian1995 Q45 & Q45t & 2000 Q45
Postby
Q45tech »
https://forums.nicoclub.com/q45tech-u112.htmlSun Nov 02, 2003 1:33 pm
To change the rings you have to pull the engine and remove the heads...........as a used engine is less expensive say $1,200 plus, $900 in R&R parts, and $1800 in labor............under $4,000.
