fogged306 »
https://forums.nicoclub.com/fogged306-u87854.html
Tue Apr 08, 2008 1:33 pm
Technically, if you want to get around fixing the alarm, you can ground the orange wire at the alarm module above the brake pedal and this will disarm the alarm permantly... I haven't done this on a J30 so there may be unlocking/locking issues afterward. I've done this on other cars, though, without a problem. The only thing could be a potential problem is that the actual disarm wire will unlock the doors seperately from the unlock wire. If this is the case, there will always be an unlock oulse going into the lock module and it will possibly cause the car to not lock. If you notice problems after grounding that wire, just unhook it.
