J30 obd1 help
joeflorida
hi everyone first time posting but ive read alot on the site so far, bought the J30 9 months ago fixed a lot so far with help from the stickys on this forum so to all thanks! my problem now is im getting a 55 obd1 code checked it three times i dont know, there was no 55 in the sticky by driverdriver anyone know what this means? the car is running but seems to be missing are starving when you take off and a slight rough idle, thanks again anyone who can help!joe
yodawill2000
Car: 94 Infiniti J30
55 is no problem found
yodawill2000
Try some Redline Sl1 (Clean clogged injectors)and maybe some Isoheet as well (Water in fuel)Sounds like sour fuel.
joeflorida
good i was hoping that, hehe but theres definately something wrong maybe its a coil pack are a injector ill unplug coils real quik and check not sure how to check injectors though? the car from1000 to 2200 rpm has like a stuttor are roughness that wasnt there before if your cruising in those rpms you can feel it and when you stop at red light it sometimes will shake the whole car its weird thats why i thought the obd would pick it up?? i dont now any ideas? HEHE thanks again yodajoe
joeflorida
yeah i thought same thing at first but ive ran two tanks threw it like it is now hehe i deliver pizza with the car so it goes threw some petrol, i ran some $8 injector cleaner threw it and i didnt notice a change
yodawill2000
Redline Sl1 has the solvents that BG44k used to have .Your injectors may be clogged.Comparing Techron or the likes is like comparing beer to whiskey.It made a BIG difference with my J on the first dose.I do a bottle once a month now.As well as isoheet.
Modified by yodawill2000 at 7:03 AM 5/7/2009
joeflorida
10 4 ill try it tommorow mornin and let ya now. i hope your right god that would be to easy..... (fingers crossed)...
yodawill2000
FYI the only place Ive found it is at Pep Boys or online. (EBay)
joeflorida
Okay its been a while i tired all that stuff the redline and isoheet still was messin up so i took off the connector on the coils till one didnt change the idle or nothing while running changed that coil, with one i ordered had to wait 2 days also put a new iridium plug in cause the other new one already looked dirty still not running different on that cylinder i dont know maybe injector??? how ya check if it is a injector ? and does anyone have a link to a how to fix article could save me some time i apreciate it? ,Joe
yodawill2000
joeflorida
Phew changing the injector total pain in A@@!I had to dremel away metal just like in the directions hehe and the old screws (like they wouldnt strip)of course they did i dont understand not being hex heads on the injector cover, so stupid to use phillips head, ended up chiseling old ones out and using new hex heads with same thread. but its done took a couple not so hard hours of work hehe But shes running strong again, its amazing what one cylinder feels like in HP loss hehe seems like more than 16% THanks Yoda for all your help man,its nice to have this place to get help from thanks to all at nico, hopefully wont need any more help i dont want to fix anything else on this car! hehe late joe
driverdriver
Car: NICO's longtime resident Canuck!!!
The 3 most labour intensive jobs in terms of time on the J are the sunroof, fuel injector replacement and timing belt.
Q45tech
Replacing the heater core takes longer than the 3 you mentioned.
J30inthe sun
Car: 1997 J30
Not to mention knock sensor replacement or valve cover gaskets.
