All the J's are the same so, yeah, it's the same.buttonfly wrote:Don't mind trying! Just this are we sure yours is a direct fit for mine ? I need to get 5 years out of it.... how long has this extra been on a car? Mine muffler dims are : about 24" length, two 1.75 inlet pipes located (enter)at a 45 degree angle in the front , two exit from the back.Thanks
What kind of noise and where is it coming from?buttonfly wrote:I've been led to believe the insides maybe rusted out enough to make all the awful noise. Looks ok from the outside. In the last year I've changed both cat's and resonators, this is the only thing left on the exhaust system that could be making the god awful noise.. right?
The rear section will unbolt. You could take it off and drive it to see if the tin can sound leaves. The exhaust tone will be louder but you could at least see if the sound you are talking about is in the rear muffler.buttonfly wrote:Sounds like a loose tin can at anything over idle. All the shields over the years have been torn off and the remainder under the hood seem ok. I've been told that the internals on the infinity muffler are carbon steel and may have rusted loose. Mounts seem ok too.
