lovebite »
https://forums.nicoclub.com/lovebite-u18670.html
Fri Aug 27, 2004 12:40 pm
Following is how I did:
Reprogram Key FobJ30, 1994-1996 Q45, 1994-1996 G20To reprogram (enter new ID) key fob (keyless remote controller) follow the steps.
1. Close all doors and lock all doors2. From the door switch unlock the trunk.3. Insert and remove the key from the ignition key cylinder six times within 10 seconds.Note:-Key should be withdrawn from ignition key cylinder completely each time.-At this time, the new ID code is entered and original (previous) ID codes are erased.4. Manually unlock and lock the driver side door5. Push any button on the new remote controller once. If there is only one remote controller skip step 6.6. Additional ID code entry: -Repeat step 4 and 57. END.
Note:-If you need to activate more than two additional new remote controllers, repeat the procedure on step 6 "Additional ID code entry" for each new remote controller. Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
What is the difference in property bewteen master key and duplicated one?
