240chibean wrote:Well I've done an extensive nico search and its been inconclusive so I'll as
I have a 95 240sx with no lsd and I want to know if an lsd from a 95 and up J30 will bolt up with no problems
By that I mean that the axle bolts will line up and I won't have to replace the axles
you should be able to bolt rigth up with no problems, if it were a s13, then all you have to do it , change the back cover plate on the s13 diff, and swap it to the j30 diff, and it should bolt on , reason is , cuz the s13 were it bolts to the subframe, the s13 has 4 bolts on the plate, and the s14 has 2.
