lok »
https://forums.nicoclub.com/lok-u5141.html
Tue May 27, 2003 3:26 pm
If the j30 is not a 95 96, check the door jam for the date. You will need the axels b/c they are about 2 inchs longer. And you have to swap your end case b/c the j30 only has 2 studs that mount to the car. It is pretty straight forward if the salvage yard will let you pull the rear end off of the j30, that way you can see how to disconnect the axels.
