J30 LSD /RB20DET
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Anyone have one installed on there RB20? I droped mine it but the drive shaft was a tad bit harder to put back on.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
its just a little longer due to the abs rotation sensor.
stock diff- 4.08
J30 diff- 3.916
Yellow4g63
Do you have one on your car? RB20? if so did you have a hard time with the drive shaft?
BoostFab
Car: S13cp, S13fb, S14z
Yellow4g63 wrote:Anyone have one installed on there RB20? I droped mine it but the drive shaft was a tad bit harder to put back on.
i have one on my car right now. i used the r32 xmember and the rb20 drive shaft... i still have lax when putting the drive shaft back on. i'm not sure about the stock s13 drive shaft though.
Modified by BoostsFed at 4:33 AM 11/21/2004
Wulfgang
Ditto. Got one in my S14 with R32 x-member and S14 drive shaft. The J30 LSD is about 3/4" longer than the S14 open diff, but it fit like stock.
I did not notice any more difficulty installing the driveshaft with the J30, but obviously there must have been 3/4" less room. Turns out I had loads of play to work with. If you bolt up the rear end of the shaft before bolting up the collar at the middle u-joint, you should be able to see how much play you have, and it should be quite a bit.
