j30 lsd on s13
kylekinnamon1989
Car: 90' Nissan 240sx SE/ SR20DET
ok. so let me get this straight?! i know there are other threads out there but whatever.. i can put a 95' or 96' j30 lsd on my 91 240 without modifications other than some longer bolts? and using the oem diff cover!? correct me if im wrong lol..
Chris28
Car: 92 s13 KA-T
correct. As long as it's 6 bolt it will line right up, if it's 5 bolt you need the j30 axles too. Don't worry those fit too. There is a lot of info on this topic, search.
kylekinnamon1989
i did search... alot, but i just wanted to confirm you know.. ahha. but thanks!
ag240
Car: 1993 Hatch, 1989 Hatch SE, 2010 Fronty SE
Get the six bolt one, keep the two long bolts from the j30 to use on your car, get diff fluid, and lsd additive, new gasket, and swap the caps.
install and take an advil.
chumbizzle
its actually a very easy and straight foreword swap. i did it on the first 240 i built. so easy i was actually hurt at the time and talked my GF through the swap as she did it. lol
skuurtin s13
Car: 1991 240sx hatch
i havent checked it out yet but my local junkyard has a 94 j30 lsd for like 30 bucks can you only use the 95' and 96' becase they have something different like abs or suttin the j30 models are from 94'to 97'
