J30 Instrument panel lights has a short (no power)
andre3718
Car: 93 Infiniti J30
Good evening everyone. I am new to the post and I have to thank you all for the wealth of knowledge that I have gained while looking through the posts here. I am an avid Nissan lover and I am now on my second J30 (93J with 163k on the dash) She runs pretty well but since I am on the forum I am sure you all know I have a problem.
The instrument panel on the J will not light up at all this is including the ashtray in the front by the cigarette lighter (which actually does work)
The problem originally started I guess with a bad dimmer switch but while I was tracing the problem and testing for power to the swith I seem to have shorted something. I momentarily got signs of power and then nothing. I was able to confirm the short since the light in the ashtray (which previously worked) was now dead.
I have tried all the fuses and I have tried to do a trace o the wiring but that is a rather large task. I have not seen anything on this online at all.
Please if anyone has any idea where the power source is for this dimmer control so I can restore power to it. Is there a fuse a relay anything. Any help would be great. Hope I was not too long winded. :crazy:
J30inthe sun
Car: 1997 J30
Did you replace the dimmer switch or bypass it? I am pretty sure it is a known issue with the solder cracking inside the switch on the earlier J30s.
andre3718
I have not yet replaced the switch. I was in the process and then got the short circuit. Now there is no power coming to the dimmer switch at all.
andre3718
What I am trying to do now is to restore power to the connector coming to the dimmer and then replace the faulty Dimmer switch. BTW thank you for the rather quick reply.
fourdrinie
Car: 2019 Q50
I know you said you checked the fuses, but I would check across each fuse with a voltmeter to make sure the fuses are really good!
andre3718
I have taken all the puses from the kick panel by the drivers floor. They were all good.
andre3718
Gusy sorry Im adding a question to my own initial post. Does anyone have or know of a good mechanic in or around Lawrenceville GA for my J30?
fourdrinie
Car: 2019 Q50
There was a recommended place called T3 in the Atlanta area that was fabulous for Infinitis....http://t3automotive.com/
