J30 Install S13
DammitBobby
Car: S13 91 KA24DET
This weekend I installed a J30 carrier in a Non ABS S13. Has anybody else done this type of install? If so what did you do with the 2 bushings that you bolt to the front of the carrier. I asked that because I think I need to cut the metal cylinder that goes through the middle of the bushing. It sticks out about a 1/4 inch. Under hard acceleration it makes a knock noise. You can see the big bolt and washer that goes through the bushing next to the driveshaft in the picture below.
Modified by rseabrooke at 9:03 PM 3/12/2005
Modified by rseabrooke at 9:28 PM 3/12/2005
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
Yep Ive done that one. That was my first upgrade on my s13. I basically bolted it right up. No cutting or any of that. I didnt use the j30 bolts though. I used the ones from the s13. The bolts may be longer, I dont know. Mine works great with no knocking sounds under any circumstances. Sorry Im not much help on that.
