Eswift »
https://forums.nicoclub.com/eswift-u367.html
Thu Jul 31, 2003 2:34 am
yeah, the fuel pressure will really mess you up.. i would wear safety glasses just in case.
you will either need to dremel, or remove the plenum. luckily the J30 balance tube makes things easier to deal with. might help to remove or swing back the hood, its pretty tight back there.
at my injector failures, i believe the CEL came on... and there was definiltey the injector ohm code in the ECU. right on with the stethescope! thats the way to do it! ( a beer bottle works nearly as well)
good luck, ive never had a 6 myself!
