placham »
https://forums.nicoclub.com/placham-u38577.html
Sun Jul 19, 2009 1:38 pm
I havent wired in a ignitor, yet. But looking at your first pic. On the side where you have 6 pins(why is there a ground?) isnt there supposed to be 6pins all going to each coil.
Try searching up posts for ignitors like z32 and like. But I think your wiring is wrong.
And ignitor heating up when Engine Keyed On sounds like incorrect wiring.
IIRC Carl H had same problem with his ignitor in his write-up. Maybe he could shed some light or someone else could?
And if that ground wire is the only ground wire you have between block and chassis. Than its a problem waiting to happen. Dont you have a thick wire from Battery to starter/alt/block?
Because that 14-16AWG wire will fry like a firecracker on 4th of July
