j30 Idle
misfit6794
Car: 93 J30
So I've got a 93 j30 with 117,000 miles. So far I've cleaned the maf and iac and throttle bodies, including the connectors, replaced the air filter,plugs (ngk platinums),fuel filter, and battery. I still have a miss/rough idle, I can't figure out whats left that could be causing it, maybe a bad battery cable? Im out of ideas, any help would be greatly appreciated.
Q45tech
Ohm each injector to evaluate the ethanol damage, test each indivual ignition coil for proper voltage and cleanliness [arcing prior to plug].
Evaluate ecu sensor voltages with Consult
