J30 help, gear stuck in park :-(
Raven2690
Car: Infiniti J30
Hey guys im new to this site and also am pretty bad when it comes to cars. Anyways whenever I try to shift my J from park to reverse, it gets stuck. Sometimes if i move the steering wheel it works but today it just stopped, I literally tried for 10 minutes straight trying to put it from park to reverse. So now i must turn on only the battery, shift my car into nuetral, turn on the car, then shift it into reverse. It drives fine but as soon as i put it back into park it locks on me. Maybe its the shift lock? if so is there a button i can press to turn off the shift lock? please help meee. Thanks in advance
xxcrashxx
Car: 95 Infiniti J30
as far as im aware, the shift lock is released by pressing on the break. i dont believe theres a shift lock switch. there might however be a fuse for it under the dash. double check there, if all else fails, bring it into a transmission place and have them chek it out.
yodawill2000
Car: 94 Infiniti J30
You should hear a slight click in the gearshift when you depress the brake.
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
the shift lock switch for the j is inside of the gear shifter, it is a black button, right under the P selector, it is facing the back seat, mine was broken a while back, but didnt lock me out, instead it made the shifter move even if the car is off, but i'm sure you have something wrong with that switch, this is what i did to get to it:
get two thin and unbendable objects (i used knives), and insert them on each side of the gear shifter button, (one on each side, driver and passanger sides), there are two lips, one on each side of the button, push the knives in a way to make these lips go inward, the button will come out, dont apply too much force as it might break the button. now get an elongated (10mm, 12mm, 14mm. i'm not sure which one, but sure it is one of them) socket and open the nut that will be exposed then...... once the shifter is out, unclamp the gear selector trim, that will expose 4 phillips screws, remove them, be careful as the shifter will tend to move to the driver side ( if it does, dont attempt to push it back, if you do, you will break the shift lock switch, i suggest that you put the shifter to N and then remove the bolts), now slowly pull out the selector box, you will be able to see the light plug that is installed under the assembly, it is a twist and pull type, remove it before fully removing the gear shifter box..... now you will be able to see the black shift lock switch, it is facing towards the back of the car, move the gear selector to the P position, and slowly move it sideways, it will be stopped by the switch, that is how i found it, i think in your case, the switch might be stuck or needs cleaning.......i hope this helps, good luck.......
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Does the shift lock release button work? There should be the little thing just to the right of the gearshifter you press down and it should release it.
xxcrashxx
i experienced that locking to the side of park when i unscrewed the screws on the gear shifter box w/out taking off the shifter knob. with that bulb that u mensioned, is that the bulb that controls the lights of the gear shifter buttons?? if so, what size light is it?
