J30 Heater blows...
cobraball
Car: J30
1996 J30 heater blows "COLD". After the engine temp is normal, it takes numerous ON-OFF cycling to get the heater to blow "heat".
Is the problem the "Coolant Temperature Sensor"? If so, where is the blooming thang located?
If it is something else, please tell me where it is located.
Thanx in advance.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
What is the coolant temperature when the heater is blowing cold?
What is the coolant temperature after it blows hot air?
When was the last time the coolant was replaced along with the thermostat?
cobraball
Car: J30
Thanks Paul for the quick response.
Paul Wall wrote:What is the coolant temperature when the heater is blowing cold?
In the middle of the TEMP gauge between C &H.
Quote »What is the coolant temperature after it blows hot air?[/quote]In the middle of the TEMP gauge between C &H.
Quote »When was the last time the coolant was replaced along with the thermostat?[/quote]A while ago.
Maybe a good flush of the system and a new Thermostat as a starter. It takes 10-15 minutes of driving to get the TEMP off "C". The TEMP rise should happen fairly fast certainly not 10-15 minutes.
OBTW, is the Thermostat hidden or easy to find? So much of this engine compartment is "Find Me If You Can".
My '33 Ford engine compartment is much easier to navigate.
yodawill2000
Car: 94 Infiniti J30
Maybe the Heater door is sticking ?
Infinitiguy19
OK see pages HA-41--HA-49 in the J30 FSM AKA Factory Service Manual: http://www.nicoclub.com/FSM/J30/1994_J30/ha.pdf
Then be sure to read the rest of the service manual: http://www.nicoclub.com/FSM/J30/
cobraball
Car: J30
Thanks for the info. Wiil do!
Clyons0203
Car: SLK55, Talon TSi, G35, Q45
Sounds like your HVAC controls arent telling the heater door to open. I have two for sale if you want to try that.
email me [email protected]
