NY94J30 »
https://forums.nicoclub.com/ny94j30-u126.html
Tue May 06, 2003 12:32 pm
You are going to have to fit the "eye" between the lens/ housing and the glass enclosure and then run the wire out b/w the two - I just imagine it to be difficult to seal around the wire so as to prevent moisture from entering. Not saying it can't be done - as Eswift said, if you do it right.
