J30 Headlight not working
J30onDubz
Car: CARS and HOTRODS
I have a J30 and for the past few months, my passenger-side headlight hs gone off for no reason at all, then, a few minutes later, it goes back on. Lately, however, it has become worse.
Is there a relay that would go bad on the J that could be replaced to fix this annoying problem??
Is this a common problem or has this ever happened with any other J30 owners??
Thanks for your help.
JON
juiceman
yeah ,headlight relay. Do a search on this site for it. Can get part from infinitipartsusa.com
J30onDubz
Only one headlight "flickers" on/off. Is this a common thing to happen?? Is there only one relay?? Thanks for your help
JON
juiceman
http://www.nissaninfiniticlub....relay
Call infiniti of scottsdale aka infinitipartsusa.com and get the relay
The above post says it all
Huns
Thanks for the tip on where to buy this. In another string, someone else mentioned the easiest way to go about changing the headlight relay - thanks. Very good advice.
