J30 Fuel Problem
Bugaboo
Car: J30
The fuel tank will hold 19 gallons per owners manual. I let the gauge go to empty. After I put in a full tank the pump says I only put in 10 to 12 gallons. Do this mean the gauge is wrong or is the tank really that small?
Has anyone else had or heard of this problem?
driverdriver
Car: NICO's longtime resident Canuck!!!
This is somewhat speculative answer to your problem. I've had a similiar problem happen to 2 non Infiniti vehicle. I believe your fuel pump/sending unit is done. You let it go to far into empty as a result it sucked in the gas gauge float a recaliberated your fuel tank readings. Do you hear a slight humming or buzzing from your fuel tank door/area?
Bugaboo
Car: J30
I have heard no noise coming from the tank or trunk area.
Does any company (Lucas, STP) offer something to clean the unit with out having to remove the tank?
driverdriver
You can try a fuel system treatment, but be warned they are more for cleaning the injectors that the tank.
Have you run a fuel pump pressure check for both the fuel pumps (there is more than one on the J) and the fuel sending unit?
If not I would suggest it.
Access to the fuel tank is achieved by removing the back seats.
DominickJ30
Car: 1993 Infiniti J30t
Two fuel pumps??? Please explain.
Also an easier way of gettin to the tank would be to remove the rear wll in the trunk, its only a couple of screws and its much easier to work from the trunk side.
driverdriver
DominickJ30 wrote:Two fuel pumps??? Please explain.
There is only one. I was thinking of another car that I'm close to acquiring.
DominickJ30
What kind of car?
driverdriver
'02 XJR I've always coveted Jags.
