J30 front strut replacement question
drape123
Car: J30 94, REAL CAI W/POPCHARGER, ECU-Reflash. (the DD) - 95 S14 KA-T Fully built gt35r@28psi when i ge
Sup guys, i ordered the j30 deluxe strut/shock kit from Joe at Infiniti of Scottsdale and attempted to install this kit today and i ran into a little problem i am hoping someone could clarify for me
the new from strut cartrages that were included do not include the lower spring seat or strut bar mount.. they appear to be welded onto the struts on the car
someone please shed some light on this! i looked up and down the fsm but cannot find the answer
thanks!
Jason
jertapper
Car: 1996 J30
I don't have the answer but am curious to hear it as I just got the deluxe kit this past week and haven't had time to try to install. I'm assuming I'll have this same issue.
I'm knee-deep in timing belt right now but plan to do the rear this week and the front after we get an answer to your question.
coolyun_98
Car: 1993 J30 11,7000kM
There is only upper spring seat (bearing + insulator) on J30. As to lower spring seat, you do not really need it unless it is seriously damages due to rust or impact. In that case, you will have to replace the whole strut assembly.
However, there are thin (brownish) rubber shields that goon the ends of the coil spring. They are pretty hard to get and I had to resue the old ones.
drape123
coolyun_98 wrote:There is only upper spring seat (bearing + insulator) on J30. As to lower spring seat, you do not really need it unless it is seriously damages due to rust or impact. In that case, you will have to replace the whole strut assembly.
so just to clarify how do you remove the bottom spring seat from the old strut? i really want to know everything before i attempt this
coolyun_98
The bottom spring seat is welded to the strut assembly. What you actually replace is the insert of the strut.
jertapper
Car: 1996 J30
coolyun_98 wrote:The bottom spring seat is welded to the strut assembly. What you actually replace is the insert of the strut.
That makes sense. I'm not sure if the spring compressor I have will be able to handle the front strut springs. It should handle the rear springs just fine. I'll be doing the front last for sure but this info will be useful as I could see myself wondering as drape did. Unless the manual spells it out...which from doing this timing belt, it usually doesn't. I'm surprised how much it leaves out. My old cadillac manual is much more detailed.
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
Advanced auto will loan you a spring compressor Free you just leave a deposit I think auto zone does the same.
