drsmoller »
https://forums.nicoclub.com/drsmoller-u124083.html
Fri Jan 09, 2009 11:30 am
New registered poster.
Just failed emissions with '97 J30. Said no check engine light on or off. This is a new one to me. Thought that they only checked to see if thing was on, but mine is just completely negative when ignition goes over and they set up the OBD. I never noticed the thing either way. Also instrument cluster constantly shows seatbelt light on. I've never worried about it, but figured would mention that.
Going to make this a DIY project. Tell you what, I really do not like the emissions stuff and truly believe this is just another way to tax us all. Getting sick of all these taxes - pretty soon they will put us all out of business.
So, DIY. I figure on checking the bulb first and don't think there is fuse for this anywhere. Okay. I also do not know how to get to the thing to check wiring/bulb, etc. Any help? And/or suggestions on things I might check as well regarding problem?
I called shop about checking it out and they were a bit vague on everything from cost to anything else about this - made me nervous. So, yeah, DIY. Another thing which makes me nervous is, if I fix the lamp somehow, then perchance the thing stays lit and then fail emissions still b/c of functioning light....GEEZ!
Thank you for any advance.
Scott
