boileralum00 »
https://forums.nicoclub.com/boileralum00-u146.html
Mon Jan 10, 2005 10:46 am
Well, since you are going to be in there anyway, I would replace the tensioner, both pulleys, and the studs to be safe, along with the timing belt. That way you know that all the timing components are new and aren't going to fail again. I would say that the tensioner was probably the root cause of it, since it has been 59k since the belt was changed, and chances are that the dealership didn't change the tensioner at that time in the first place.
