adroitcaptor »
https://forums.nicoclub.com/adroitcaptor-u184023.html
Tue Mar 05, 2013 1:53 pm
You have got to be kidding me! I wrote this long response and it all got deleted because I was not logged in... epic failure. This one will have to be much shorter so please forgive my brevity.
Regarding the mapping:
The numbers across the top are throttle position/'load'.
The numbers down he left side note the RPM.
The numbers in the middle represent AFR at the correlating RPM and TP.
The colors are to help easily identify your AFR representation. (Most have more colors; some can even be shown in a 3D model that depicts duty cycle or many other parameters.)
Regarding the ECU changing mapping:
Fist, how it works on a very basic level. - The ECU sends a specific voltage to MAF. The MAF 'uses' this voltage to heat an element. When that voltage must increase to maintain the same temperature the ECM knows more air is flowing through the MAF. (Not all units work in this way but as a generality, in this applications, and for purposes of explanation...) The voltage that 'get sent back' to the ECM will tell it how much air is going into the engine. The ECM then compounds this data, along with many other inputs (temp, throttle position, etc.), to controls the duty cycle of the injectors. There is a lot more at play including RRFPRs and the like, but on a basic level, I hope the above serves to clarify/help.
So why would this affect the car running when the engines are so closely the same? - There are a few aforementioned variables here to look at. The MAF and ECU being the biggest two. The MAF can vary in operation but also in its voltage range. Most will increase linearly with RPM but an ECU looking for a specific voltage and seeing another can change the whole map. The ECU can supply a different voltage, read different voltages from sensors, or give the wrong 'type' of signal to the injectors.
Your problem - The J30 and the Z32 have the same MAF. They also have very similar engines and ECUs. One specific place they do differ is the ECM set voltage for the MAF supply. The J30 sends a 0.8VDC primary signal where the Z32 a 1.0VDC. This could account for the fundamental change in AFR. However, I would have to do a lot more research into the ECUs to know all the differences.
I hope this helps answer your questions. I am no expert and own neither of the aforementioned vehicles (though I hope to buy a J30 today).
dan
