ztommyx wrote:
i know there was a write-up on it. this set-up does not need the skyline ecu.
here's a few pics i took from them as a note and visual.
i have a few more pic but this write up is for DYI. i just lost the bookmark for it.
if you wanted to run a dual intake setup wouldn't it be safest to monitor the airflow on each throttle body and cylinder bank to ensure that one side doesn't run leaner or richer than the other? I know the 350's use twin mafselwesso wrote:not sure what the advantage to running dual MAF? The N62 MAF definitely is not causing a lot of restriction to the N/A VG30DE...
