Replaced door latch today
Was smart enough to get door panel clips as suggested, as three broke so i used all new and save the old.
Took alittle finagling but finally got it out and replaced. Actuator was working fine so i did not replace this.
Instructions from
http://www.carstereohelp.com were right on and made removal easy
still had the Airbag light flashing diagnostic mode with no trouble codes and could not get off. Did a search on this site and found the instructions to reset the Airbag diagnostic. I guess when the door switch broke and the lock mechanism was working when the door was able to open and I somehow put the airbag into diag mode.
All is well and thanks to Frank at Scottsdale for the help.
NExt job, Tension rod bushings.
