nissan~240sx wrote:i have a nissan 240sx 93'. i want to get into drifting and in order to do that i need LSD. now, would a j30 lsd fit on the 240sx? which is cheaper? more effective? is the diff 1 way or 2 way?
Yes the J30's rear diff will fit. You just need to find one with the same bolt pattern as your car on the output shafts. The 95 and 96 year model J's have the same as yours as do some of the 94 year model J's. (My 94's is the same as the 240's)
You ask which is cheaper but only talk about the J30's rear diff so what are you wanting us to compair it to?
I don't know if it's one way or two. It's a viscous LSD. I don't think they rate them as one way or two way. Here's a clip I found on wikipedia:
The viscous type is generally simpler, and relies on the properties of a dilatant fluid - that is, one which thickens when subject to shear. Silicone-based oils are often used. Here, a cylindrical chamber of fluid filled with a stack of perforated discs rotates with the normal motion of the output shafts. The inside surface of the chamber is coupled to one of the driveshafts, and the outside coupled to the differential carrier. Half of the discs are connected to the inner, the other half to the outer, they alternate inner/outer in the stack. Differential motion forces the interlocked (though untouching) discs to move through the fluid against each other. The greater the relative speed of the discs, the more resistance the fluid will put up to oppose this motion. In contrast to the mechanical type, the limiting action is much softer and more proportional to the slip, so for the average driver is easier to cope with.
