to be exact. you are correct about the 95"+s but the pre 94's are also able to be swapped you only need the axles from the j30 they came off of or the "5 star" axles which have 5 bolts that connect to the dif. the 95"+ have 3 star have 2 bolts for every tip which there are 3 tips. any j30 diff can be swapped to a s13/s14. but depending on the year you may need the axles. also driveshaft is somewhat important. abs diff's dont need but it is recommended that you have the abs s13/s14 shaft(depending what the diff is going into). non abs diffs need the non abs shaft that corresponds to the chassis it is being swapped into. also autoshaft will not fit into 5 speed transmission's. basically it all has to match eachother. remember all this and you'll be good to go.obg3506 wrote:my understanding is that the 95+ j30 diff is a direct swap into the s13 as long as you swap your cover to the j30 and the drive shaft differences is negligible!! somebody confirm, as i am a s14'er
yep just get some quicksteel and the biggest damn washers you can find lol. my s13 dont have abs and my lsd (j30) went right in no problems been running it over 8 monthsSketchyRollin564 wrote:To mount a j30 vlsd to an s13 you also need to get solid bushings to go where the front bolts would bolt up
the s14/j30/300zx diffs came with rubber bushings, where the s13 didnt have bushings and they were just mounted metal to metal
DAMN!!!!!!martins_240sx wrote:...First time i downshifted the j30 found a new home on my sway bar...ripped the studs out of the cover and leaked fluid out everywhere...
HOLY $hit! you paid $50 for those spacers?
just got the same ones myself the other daycosta_rican13 wrote:i paid 74 bucks for my stance aluminum bushings.stance is the isht
gotta love the name brand stuff. lol.splintercell wrote:just got the same ones myself the other daycosta_rican13 wrote:i paid 74 bucks for my stance aluminum bushings.stance is the isht
