J30 diff question (about driveshaft)
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Stronger axles. Q45 VLSD have the shorter 3.69 ration and can use the stringer axles. But in my case I am using the Q45 rear with S13 welded guts and 6 bolt axles. Its a different ring gear and pinion. The pinion is much larger.
Skilz10179
Car: 98 240SX
Just listening in....
I'm a S14 non-ABS owner who also just bough a J30 VLSD...
ronin083
Car: 98 240sx
98 s14 with a 96?(did my homework at the time forgot now) j30 diff, bolted right up, swapped out over a year ago, the difference between the ABS sensor added like 1/8 in to the diff, driveshaft fit right up, little slower on acceleration with stock KA, but makes a world of difference in my friends SR20, full grip from both wheels instead of spinning on one, no problems at all, cut off the sensor wire thingy and took off, off topic. I think j30 axles will work for 240's as well? May be slightly longer? correct me if I'm wrong
IDRFT95S14
Car: 1995 Nissan 240sx SE
no there the same ,i compared them when did mine but i kept my 240 axles i still have the j30 ones laying around
