j30 diff bushing help.
costa_rican13
Car: 1993 s13 coupe
so i just got some stance j30 bushings. and well i need to remove the old rubber bushings. my problem is when i pushed out the old bushings the whole bushing didnt come out. in the middle metal tube with some rubber came out. so i still need to push the rest of it out... can any of you guys give me some advice as to how you all pushed it out?
costa_rican13
Car: 1993 s13 coupe
nobody ever push them out?? idk how.
costa_rican13
Car: 1993 s13 coupe
bump
ChampionSound
Car: 1993 Coupe LE
pretty sure if i understand correctly most people will just burn the old ones out. unless i am completely misunderstanding your post
s13sickboi
Car: 1997 Nissan Hardbody XE
get a sawzall and let the man in you manifest itself :dblthumb:
costa_rican13
Car: 1993 s13 coupe
the rubber part with the metal tube that bolt goes in already came out. its the rest of the bushing which is metal.
whats sawzall? im not understanding your post..manifest what?
motoman399
Car: 98' wrecked (RHD coming soon) 240
s13sickboi
costa_rican13 wrote:the rubber part with the metal tube that bolt goes in already came out. its the rest of the bushing which is metal.
:picard: Image
use this^ and cut the bushing....
costa_rican13
Car: 1993 s13 coupe
lol oh! ok but i dont have one so i will have to find one... any other ideas??
JayArr
Car: 1990 Nissan 240SX Coupe
Have you taken a goood look at your new bushing set to make sure it has outside metal rings?
Some of the sets tell you to leave the original outer metal inserts in the arm, clean it out and the new bushing fits into it.
Make sure you've read all of your instructions because if you push it out or damage it the new bushing may not work and then you have to go buy OEM rubber bushings to start over.
JayArr
If the outer metal ring does need to come out then use a tool like this:
http://www.amazon.com/Astro-Pneumatic-7 ... B00061SGZO
or this:
http://www.automotivetoolsonline.com/AP ... 14387.html
costa_rican13
Car: 1993 s13 coupe
JayArr wrote:Have you taken a goood look at your new bushing set to make sure it has outside metal rings?
JayArr
or this:
thanks jayarr! but i already got it out. i used a 15/16 socket from a socketwrench. and banged the heck out of it with a hammer. :) i have the Stance broze anodized aluminum bushings just fyi. and the socket is a perfect for everyone doing the swap that needs to remove the bushings on the fron to fo the j30 differential. thanks guys for all the hlelp it is greatly appreciated.
