j30 died
tru3aznplayaz
Car: 1995 Infiniti J30
theres something wrong wit my j30..wen i drive it for awhile it just dies on me and it wont start until i let it sit for a long time like the next day...and it will start up just fine..but wen it dies it starts up but wen i give it gas it dies...please help me and telll me wats wrong...
yodawill2000
Car: 94 Infiniti J30
Get a check engine code and let us know .Autozone will do it free.Could be one of 100 things ,,, kinda thing
RZAA36
Car: 1993 J30
I would bet it is your fuel pump!!!!!
tru3aznplayaz
yeah ill do that..and forgot to say..the check engine light do flashes on and off...and the fuel pump i just changed a month ago..could it go bad again..
fogged306
Car: 1997 j30
Check your voltage when the car is running with a multimeter. Just a thought. Maybe not the problem because you can start it at a later time after it dies, but it could be your alternator. I've seen it where a battery can gain enough charge after dying and then letting it sit, to start the car.
FunkRider
These are symtoms of a hull effect sensor going bad once it gets hot. Check the cam and crank sensors.
gr8scott72
Car: 1994 Infiniti J30t
FunkRider wrote:These are symtoms of a hull effect sensor going bad once it gets hot.
Huh?
Captain, she can't take another hit to the hull!
RZAA36
Car: 1993 J30
tru3aznplayaz wrote:yeah ill do that..and forgot to say..the check engine light do flashes on and off...and the fuel pump i just changed a month ago..could it go bad again..
IT SURE CAN!!! I've seen it alot when a new pump goes out. I was a service manager and I've seen alot of crazy things
misfit6794
Car: 93 J30
Sounds alot like a crankshaft position sensor or cam sensor. I had a northstar caddy that have crankshaft sensors fail constantly, you sound like you have the exact symptoms. Thats probably why its throwing a cel, and you probably have the corresponding code.
yodawill2000
Needle in the haystack man !!
Get that code !!
tru3aznplayaz
ok ill drive it up too autozone and hope it wont die on me on my way there hehe..
brandonjustice93J30
Car: 1993 Infiniti J30
Captain...we need more power...
gr8scott72
brandonjustice93J30 wrote:Scotty...we need more power...
(fixed your quote)
I'm givin it all she's got captain!
kbflip02
2006 Infiniti G35x
tru3aznplayaz wrote:ok ill drive it up too autozone and hope it wont die on me on my way there hehe..
i dont think autozone can scan it...if im not mistaken is an OBD 1...check the sticky on how to read the codes...
BrokenInluxury
Car: Infiniti J30
Did you ever fin out what was wrong with yours? I have one and the same thing is happening.
