J30 Diagnosis port
j30WAY
Car: 1993 Infinti J30
Hey all, I just rented the OBD2 tool from Autozone to see whats up with the J. Now on my 2000 I30 the port is right under the steering wheel, However on the J I cant find it. There are a couple of port looking things underneath the steering wheel, but none of them fit the Tools port. Do I need a special adapter? or is the diagnosis port located somwhere else? Its a 1993 J30 non touring. Thx again.
Mike
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
The 93 J wont hav ethat... its only for OBDII
driverdriver
Car: NICO's longtime resident Canuck!!!
You need to find yourself and OBD1 tool.
elan
Car: BMW 328I, Had J30 95,
OBD2 is implemented on 96 and up. For 93-95 you need OBD1. Also I think the codes can be read with some of the light on the dash after you short some contacts. I do not know how but I read it can be done.
elwesso
2007 BMW M Coupe
you take the ECU out, turn the screw, and count blinks..
yodawill2000
Car: 94 Infiniti J30
As wes said ..the ecu is behind the passenger side kick panel ..theres two bolts that mount it ..remove the bolts and GENTLY turn around so you can access the screw and see the led .
heres how to read the blinks .http://www.nicoclub.com/articl...shtml
DominickJ30
Car: 1993 Infiniti J30t
The port is under the left side of the steering wheel.
But you either need a Consult or a compatible scanner with the right adapters.
