Checked for any codes?leedrm wrote:OK, I am running out of options and convince that the dealership is wrong.
1995 j30 128000 miles. Love it. owned for 10 years. I can drive about 65 miles and the engine cuts out, like its flooded. Cant drive over 20miles an hour. No check engine light.
When running good engine idles sometime good sometime like a miss.
Solution 1.changed fuel pump and filter.....Same thing
Soultion 2.got used MAF for 30.00 (tested good) same problem
Solution 3. Got new MAF same problem.
I am thinking either clean fuel injectors or TPS...
one more things...when gas was stupid high, I ran maybe 2 tanks of 89 oct in car....I was thinking of a remote problem could be timing, due to cheap gas...
please help...running out of solutions.
possible FPC....check the relay in the fuse box for your fuel pump....also if you did run 89 octane i would run some seafoam....however i am leaning towards the TPS...leedrm wrote:No codes....Nothing.
No codes stored on the ecu, checked by means of pulling ecu out and looking at blinking light on side? Or no codes meaning no check engine light?leedrm wrote:No codes....Nothing.
Finally, another NICO member in Mobile, AL!!!!!! Welcome to NICO!!!!!leedrm wrote:OK, I am running out of options and convince that the dealership is wrong.
