J30 Cruise Control Trouble
starkjoe
Car: 2004 Pathfinder
My cruise has been out for a while and I am trying to get it working again. The cruise still turns on (green light on button illuminates) but it will not set (illuminate the "cruise" light in the instrument panel). I have gone through the service manual troubleshooting all the way to the relay under the hood. But I have no way of telling if this is bad or not.
Does this sound like a relay problem? Are those easy to get?
Any advice on the matter would be appreciated.
Thanks
elan
Car: BMW 328I, Had J30 95,
is your speed in the working range ? I believe it's 40 to 96 mph or someting
Defiant
Car: 1997 J30
Lube the cc cables and linkage. Swap the relay out with another if testing isn't something you can figure out.
starkjoe
elan wrote:is your speed in the working range ? I believe it's 40 to 96 mph or someting
Yeah, most of the time I try I am doing 60 or so.
Defiant wrote:Lube the cc cables and linkage. Swap the relay out with another if testing isn't something you can figure out.
Defiant - can I swap the cruise relay out with any old one?
------------------------------------thanks for the fast response
littlewillie
Modified by littlewillie at 7:04 PM 12/24/2007
