Skapunk4everr »
https://forums.nicoclub.com/skapunk4everr-u35112.html
Tue Mar 14, 2006 4:06 pm
Hey guys, I have not posted pictures of my custom CIA that i made. It is Home made, but it works quite well. Heres what i did
I removed the entire stock airbox and then i cleaned the area up. following this, i cut a square with my dremel, ( i have a big one and a little one) i used a huge disk, with a radius of about 3 inches. I was real carfeul to make the cuts straight and it was much easier that it seemed. Next, i installed my adapter that i got on ebay for the Nissan cars ( of course it did not fit all the way so i drilled two more screw holes to make sure it sealed up correctly.)
Now for hte tubing, i purchased i belive a tacoma CIA tube, that had a nice 90 degree turn in it so i could go straight from my MAF down into my wheel well. I cut the side of the tube down to the height that i wanted, and as you can see in the pictures, i could have gone shorter with the height, but i can fix this later.
i then placed electrical tape ( black) around the edges of the cuts, so they did not stich out as much, and a further thing that can be done is to some how fabricate a rubber grommet to cover the rest of the squar but i have not done this yet.
I trimmed away some of the cover conected to the bumber cover in order to fet a nice smooth airflow into my filter.
Here are the pictures, click on them to enlarge.
Through the front bumper
i did notice some gain, but i have no dyno test so i am not going to put out any numbers.
ok thats it for now, if anyone needs any special angles just feel free to email me and ill try to snap a shot.
