Grizzly49 wrote:A first time Infiniti owner - 1994 J30 (moderate mileage 157K). First week CD player went dead. Then doors locked by themselves. Last couple of weeks the check engine light will come on intermittently, not always. Seems to happen when the car warms up - after a couple miles, then goes off after a while. The last time it happened the car began to shudder, like the engine was missing. If I gave it gas it accelerated ok, but would shudder when holding speed. When I got off the freeway (ran quite rough at idle also) after a couple of stop lights the check engine light went out and it ran just fine again. The ECM displayed codes 32, 34, 51 Can all these things go bad at once? Please advise!Hope this isn't just the beginning!Great bulletin board!!!
There are members here that have delt with the radio problem. A connection in the dash. Not a huge deal. Hasn't happened to me yet as 95 to 97 Js don't seem to suffer as much from this.
Your door lock timer is failing causing your doors to act up. Common problem and a cheap fix. There is a recent J30 thread where I posted some info I have regarding said gremlin.
Mass Air Flow sensor causing the idle problems? They have connections just aft of the air box that can jiggle around before they fail causing rough running.
You say moderate mileage. If you mean 157kms then that would be moderate. 157K miles is getting up there.
That you're having these well known problems (CD player and door lock timers)is interesting if you have miles not klicks. Usually these things happen around 50-80K miles. Either you are on your second set or yours have lasted many billions of vibrations from road travel.
Don't worry about these things too much. They are fixable. The engine can go and go so don't fret too much about that if the oil has been changed properly over the years.
The transmission? Now there is another interesting thing. The trannies are only average in durability. However, when maintained they will last a long time. I have heard stories of them lasting over 200K miles and of them failing after 40K.
The J30 is one of the most reliable and well engineered cars on the road. It also has the lowest accident fatality rate of any car ever manufactured. Ask JPalm, one of our moderators about that. Read the posts that appear here, get your codes checked out and happy motoring!
