Brake Job-- I dont know.... But it would be a GRAND time to flush all the brakes and replace the fluid with valvoline synthetic brake fluid.......
Filters-- Get ONLY (especially fuel filter, you dont want crappy filters clogging you injectors) NISSAN OEM filters...... Best place is to get them from Joe at scottsdale.........
http://www.infinitipartsusa.com
Along with an oil change, it would be good to possibly get a transmission flush, and if you have the cash, get a pressurized fuel rail flush (preferably a BG flush)...... Along with that, do an engine decarb...... Goto your nearest GM dealer, and pick up a can of TOP ENGINE CLEANER (the liquid NOT the aerosol), and run that through the brake booster line....... I got a tiny funnel and just poured little amounts of the stuff into the hose....... get a friend to keep the RPMs around 1500.......
And if you are going to get a thermostat (i dont know what a stick open tstat is, but if it is one that stays open all the time, its no good), it would be good to flush the cooling system...... I am going to do that this weekend, along with a TSTAT change.... I would run some of that prestone radiator cleaner stuff for about 100 miles prior to flushing.....
And when you flush, fill with 70% water, 1 bottle of redline watter wetter, and the rest AF........
