J30 Brake Conversion?
takchi
I read up on the J30 brake conversion and supposedly the J30 brake set is actually almost the same as the Q45. What brake pads would you suggest you use for this application? Can these brake pads be searched under the Q45 title? Thanks.
kamikazestorm420
J30 is the EXACT same thing as Q45 brakes
