J30 Bose stereo - fuse problem?
jolee
Car: 1993 Infiniti J30
I'm excited to find this site! I searched here and everywhere and I'm ready to humbly asked for help. I bought my 1993 J30 w/ 155k for $3800 and loving it. Only problem the previous owner had was w/ power antenna, but I picked up my stations fine so not an issue for me. The problem I'm having is this....When I was getting new tires during the first snow storm, I asked the mechanic, by the way, change out the cig lighter fuse so I can charge my cell phone. (It went a few months earlier.) When leaving the shop, he muttered something about no guarantees on electrical, but I didn't think about it because the lighter (aka phone charger) worked ok for a day. Then it and my Bose stereo system went out (green CD light stays on though). I looked at the fuse box under the hood, as shown in owner's manual, didn't see stereo fuse marked, then was intimidated by the electrically taped wired under the driver's side dashboard to look much further. I think the 2nd fuse box (2nd not shown in manual) is metallic and down there to the left. Is this where the cig and stereo fuses would be? Should I look here, be suspicious of all the taped wires and leave it alone, or what? I don't mind a little zap and prefer it over going back to the shop and getting hit w/ my car taken apart and a huge bill for an electrical wiring issue. I'm a lady scientist (not mechanic) but very good at following instructions and reading diagrams. Any help guys would be much appreciated (including a cutsy lady icon for future postings-smile).
yodawill2000
Car: 94 Infiniti J30
There is a fuse box behind the drivers side kick panel that has more fuses in it than Carter has pills !!If your lucky the diagram is still there , if not search this site and you can find it.Hope this helps and good luck !!
Welcome to Nico !!!Best resource for Infinti's in the Wurlde !!
driverdriver
Car: NICO's longtime resident Canuck!!!
Welcome to NICO!!!!
(1.) I would check the fuse.
(2.)If that isn't the culprit, I would check the connections on the bose unit. To check connections basically follow the instructions for removing accessing the stereo and climate control unit found in this document:
http://fuzzycats.com/docs/ac_controls_bulbs.pdf
The stereo is a known weak point on the J30. Most of us long time owners have replaced it once. You have a choice between refurbished units found at any Infiniti dealer or aftermarket.
