I'm having a hard time locating some LSDs out here in cali. I've owned a j30 LSD before, both the 5 bolt and 6 bolt flanges, I prefer the 6 bolts (I think the newer year made a difference).
I've used the 5 bolt axles with the 5 bolt output flanges, but my question is: "Would pairing the z32 lsd w/ the J30 axles work?"
I know other folks out there would tell me to SEARCH, well I have. And I'm also sure that others will say that if I can find j30 axles, I can find the LSD. I'm simply asking this question to see if I can source more cars for parts (z32 and j30 instead of just the j30). I'm also curious to see if the z32 diffs are stronger or lock up earlier than the j30. AFAIK, the only diff is that the z32 has the same gearing that the s13s have and that the j30 have shorter gearing.
