Naison wrote:So I was gonna replace my bose radio with aftermarket one, got harness adapter and hooked all of the wires together by the schematic between the harness adapter and the new radio harness,plugged it in after that and nothing.The new radio started but there was no sound at all.After that I tried to put my old one and it didn't work too.I don't know what happend.I measured the wires with ommeter and the two hot wires(the direct 12+,and the one through the ignition) are connected correct.The problem is that when I measure it shows that the rest of the wires are ground and it shouldn't be like that right? I don't know so much about electronics but shoudn't be only one ground in the whole harness. Any suggestions pleaseIt's pretty bad without music in the car
I wanted to start from the beginning. Before getting into line modification you need to check the basics. At this point you have probably caused a short small enough to blow a fuse. You need to check all the fuses, sometimes the short in another or problem in the antenna will effect sound output. If you have measure resistance that is actually jumping ahead. You need to check for constant hot on Yellow, key on power on Red. Ideally you should be using something like this (
http://www.amazon.com/70-7550-...BG6B4 ) to match the corrosponding wires on the aftermarket harness. With the Bose system you need to be make sure the amp on signal wire is running through the auto amp signal relay to power up the amplifiers. This is terminal twelve (light green w/ a black tracer) of connector M96 the smaller of the two larger white connectors on the back of the radio
The line input modification boxes you guys posted here are great for some things and that is exactly the product I have been looking for after installing an Alpine version of the cleansweep in an Infiniti that has a noticeable loss in gain but suppurb output. I wonder if this would work without altering a digital output signal from a processor and before the stock bose amp? Sorry to go off topic a little but I have been brainstorming about that for a few days.
