J30 amp power wire
Post all your Nissan electronics, car audio and stereo questions here!
zipprj30
i just bought subs and and amp and i am having a few problems trying to find a way to get the power wire from the engine bay back to the amp in the trunk. any pictures or advice will be helpful, thanks. :D
Rex
Car: None
It may take some "seardching", but I've been told there is open space in the frame rails for running things to the back in a Q45, gotta figure the same is true for the J30.
Beyond that, you can usually find an existing grommet or hole on the firewall (prefferably on the passenger side), but make sure you're not using the pass through for the ECU wires.
There's at least one guy with a serious system in a J30, he's got a post on here about his kick panel install, try emailing him through his user profile.
