J30 Alarm problem
koree
Hi,
My j30t is currently experiencing a big problem. Often, my remote will not work. The remote doesn't seem to be the issue, as i've replaced the battery and it makes the beep whenever i press a function. Nonetheless, my car often doesn't respond to the remote and i am forced open manually and start the car. This is not an issue, but when in this situation, i let someone into my car before i start it, the car's alarm will go off, and the engine won't start. When the alarm finally does stop, i often have to wait several minutes before i can start the engine again. Until last night, and over 12 hours later, it seems my car still won't start. Any help would be greatly appreciated.
Koree
yodawill2000
Car: 94 Infiniti J30
Welcome to NICO !!If you lock and unlock the drivers side door with the Key it should disable the alarm.
koree
Thanks yoda, however, i have tried that, no luck...
yodawill2000
Hmm.Maybe the Timer is bad ??
koree
It's working again, kinda spontaneously. I'm going to take it into a shop soon.
Thanks for the help yoda.
Koree
