j30 aftermarket???
nismokid
ok heres the deal, my 240 was totaled about two months ago and have since been looking for the right next car to purchase. i loved my 240 but now want something bigger with a little more power and still in the nissan family. thats where the j30 has really caught my interest (v6,rwd,luxury). ive searched but i still have questions about the aftermarket parts available for the j. Does anybody make intake and header. i would really like to find a header because an intake is fairly easy to make yourself. im not looking to make huge power gains with this type of car but a little bump in power would be nice. any other info would be appreciated i.e websites or anything else as i am really interested in getting a j
thanks
Eswift
Car: should be obvious enough
intake is easy enough to make at home.
headers.
the stillen 300zx headers should bolt right up to the block.
the question remains is if they interfere with the steering column or rack in the J30.
obviously, a custom (header-back) exhaust would also need to be fabricated. (or just modify stock, if it is still holding up)
diamondj30
Car: Not to low , not to high , just right .
headers can be made, and gears is best.10 over.20 mpg,using cruise ,just cleaned my intake.436 gears are what im using.redo exhaust.muffs cats.not shure about mileage with a normal j30.im thinkin lighter the better.car shifts less easier to get around period.
Mayhem_J30
Car: Ummm...My Car
the J30 might be more powerful but it's haulin around a lot more weight. a health J30 should be running around 16.1 in the 1/4 mile. it's a great ride with luxury to the max! the interior is primo! If you want to sacrifice RWD I would go with the I30. It has more usuable torque in the low rev range thanks to the great VQ motor. That makes it a lot more practical in daily driving and a little red light racing here and there.
diamondj30
torque steer sucks.what do you think mayhem.and top speed w/gears is 123.get and obd1 car that way you can raise the rev lim.and go faster w JWT ecu.jet doesnt move the limits.5K in overdrive thats all you get stock.mayhem has badass j30.
Mayhem_J30
Car: Ummm...My Car
torque steer doesn't seem very present in the I30. maybe the LSD helps. dunno. it's very apparent in the VQ35 (hang on with both hands tony!)
i don't recall the fastest i've been in the J30, diamond. it was over 115mph for sure. might be draft limited by the top speed rather than red line or ECU.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
Not much torque steer in my 2000 I30, but save your dough, and get a used I35. The power band seems a lot stronger (more than the 43 HP would suggest).
This might be the last year for the I35, since Infiniti is going all RWD. The I35 will go away. A new M35 will take its place.
diamondj30
stock top speed 133.checked it out around vegas when i went.car stops going at 5,000 rpm.123mph.very stable.no float at all.probly cause of the rake i would guess.way stabler than any loner ive got at 55.45 mile corners at minimum of 70mph
