Update. Thanks for the replies, J30 leopard.
I completed my Bose head unit replacement project. Everything went off without a hitch. As stated by J30 leopard, I had to use the OEM metal bracket to mount the new head unit (ISO mounting).
I also used this adapter (
http://www.crutchfield.com/cgi...4NN03). It allows you to replace JUST the Bose head unit in Nissan/Infiniti cars without the need to replace the Bose speakers and amps. It basically converts the amplified "high level" speaker signal from the new head unit back down to a low-level signal (just like the signal from the Bose head unit). Best of all, it comes with the Nissan/Infinti harness so it just connects to the existing harnesses in your car. The other end connects to the new head unit.
I'm very pleased with the results. I bought all my stuff from Crutchfield. I did, however, have LIE to the Crutchfield web site. I had to tell it that my car is a 1995 Nissan Maxima w/Bose system. If I told it I had a 1995 Infiniti J30, the site would tell me that nothing they sell fits my vehicle. I happen to know that the head unit in the '95 Maxima is the same head unit in the J30. Keep in mind that this trick only works for replacing your head unit. The speaker sizes are probably different between the J30 and the Maxima.
In any case, by doing this, Crutchfield sent all the appropriate goodies to do the install on the J30. The goodies were: Nissan FM antenna adapter, Nissan installation kit (plastic storage pocket). These fit the J30 just fine.
The system sounds great and I now finally have a AUX input for my beloved XM satellite radio.
Carlos
