J30 95 Model
TFW3
Car: 95 J30 Infinity
Can anyone help me in explaining how to replace a Fuel Filter for a 95 J30?Just wanted to make sure I did it correctly and should I be aware of antyhing.
I appreciate it.
gr8scott72
Car: 1994 Infiniti J30t
TFW3 wrote:Can anyone help me in explaining how to replace a Fuel Filter for a 95 J30?Just wanted to make sure I did it correctly and should I be aware of antyhing.
I appreciate it.
It sounds like you've already done it? I'll explain the best I can anyway.
It's located on the passenger side of the engine inbetween the engine and the shock tower.
1. Unscrew the clamp that hold the filter in place.2. Unscrew the two hose clamps, one on each end of the filter.3. Remove hose from both ends of filter.4. Installation is opposite of removal. Make sure filter is oriented the right way when installing.
Oh, and welcome to NICO.
TFW3
Thank you very much! I appreciate it. Great Directions Also!
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
you might want to relese the pressure in the fuel lines before you change the filter..... but the procedure is absolutely as gr8scott72 said
elan
Car: BMW 328I, Had J30 95,
yes, do not forget to release the fuel pressure before that for this turn off the ignition and take out the fuel pump fuse - it is located under the hood
they start the engine and wait for it to stall.
now turn the engine off and replace the filter.
releasing the pressure is highly recommended for safety reasons
