J30 94 DASH LIGHTS WHENT OUT!! PLEASE HELP
JoeBlowj30
Car: 1994 j30 infiniti
Whats up everyone. I got a quick question. My dash lights, clock light and radio lights went out. At first they would go on and off. All i had to do was tap the dimmer at bit. But yesterday they went completely out. I replaced dimmer, replaced the "clock" fuse. Still dont work. I even jumped the green and yellow wire together and still nothing. Last i changed the white piece ( the piece that has the 2 green and yellow wire wire) that connects to the dimmer. Still nothing please help. 1994 j30
yodawill2000
Car: 94 Infiniti J30
Sounds like your switch just need's the solder points redone. (Resoldered)
Quite common, and a very simple fix.
:welcome: to NICO !!
JoeBlowj30
Do u mean the dimmer switch?
yodawill2000
Yes.
remove the dimmer switch and you will see solder points on the little circuit board.
Just apply fresh solder on each point.
Its one of the first things I had to do on my J.
JoeBlowj30
But the dimmer switch is good. I tried it in my other j30 and it worked.
yodawill2000
Interesting. When you said in the beginning Tapping on it made it work,
That's exactly what mine was doing. Till I resoldered it.
JoeBlowj30
If the dimmer and fuses are good. What else might the problem be?
fourdrinie
Car: 2019 Q50
are you getting 12v to the dimmer switch?
JoeBlowj30
I dont know. How would i be able to find that out?
yodawill2000
with an ohm meter ground the negative probe and see if any contact has +12v
JoeBlowj30
Will do. Ill give it a try and see what i get. Ill be back!!
JoeBlowj30
I tried it and I'm not getting a reading from any of the wires.
fourdrinie
Car: 2019 Q50
Go back to the fuse box and recheck the fuses with the ohmmeter
JoeBlowj30
Is there a particular fuse I should check? Or should I check them all?
fourdrinie
Car: 2019 Q50
I am not sure of the specific one, but good time to check all!
Set it on DC volts, go across fuses in the box and make sure u get 12v across each fuse
JoeBlowj30
So while i checking fuses. I get a little impatient and smacked the fuse box and all the lights pop on! Lol. I know it wont last long but by me smacking the fuse box and it comes on. Do u guys think sumthing can be loose down there?
fourdrinie
Car: 2019 Q50
Duh!
acklac7
Car: 93' J30
THERE ARE 3 RELAYS ON THE BACKSIDE OF THE INTERIOR FUSE BLOCK! 2 ACCESSORY RELAYS AND AN IGNITION RELAY! BLASTED NISSAN DOESN'T LIST THEM ANYWHERE BUT DEEP IN THE SERVICE MANUAL WIRING DIAGRAMS! GAH!
Rant off.
I strongly suspect one of the (accessory) relays is sticking, and when you smacked the fuse panel it came loose. If you keep having problems pop the panel out and replace the relay(s).
