95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Sat Oct 13, 2007 1:57 am
sorry guys for not posting any updates yet, i ran into some family issues for the past while.... it's all good now though... i'll be posting a video of the Jtt in the next couple of days.....
about the ECU thing... if your car is an OBDI (1993-half of 1995) then you will need to swap the ECU (auto or manual will both work if you are dropping in a manual transmission)
you will need to relocate the emergency brake.... find a place for the clutch pedal... run lines to the transmission.... you are also going to run in to some electrical work (wiring harness for the manual is simpler than the auto, but will need some modifications, i would suggest searching a good 300zx website for a writeup).... you will defenately need a drive shaft (auto and manual drive shafts are different) however, after research i found some J30's with the bigger driveshaft (if that is your case, then you wont need a new one, it would fit right in)
the hardest one i would guess would be the relocation of the hand brake, and locating the clutch pedal in a good spot..... other than that, it shouldnt be that hard.... make sure you know a good welder and a machine shop before you attempt such a project.... i asure you that you will need them...
well, i'll think more about it once i get rid of the hang over, i hope this helps, good luck
